95 blazer third brake light not working
Old Feb 23, 2007 | 02:41 PM
carlo's Avatar
carlo is an unknown quantity at this point
Default 95 blazer third brake light not working
i have a 95 blazer and my third brake light is not working. ithas LED lights so i dont think it can be the bulbs right. does anyone know what is wrong and is the only way to replace it to buy a whole new light?
thanks in advance
carlo
Old Feb 25, 2007 | 04:36 PM
filstoy's Avatar
filstoy is an unknown quantity at this point
Default RE: 95 blazer third brake light not working
Yes I think you have to replace the whole unit. Check to see if you have voltage going back to it when you hit the brakes first because often it is a bad connection and not the light itself. Use a test light or a volt meter. It gets it's power from the TCC Brake And Cruise Control Release Switch so you will have to trace it back if there is no voltage. Usually a white wire.Some GM models have a relay in between for the third brake light. Not sure about yours because I don't have a schematic for a 95.
Old Jan 11, 2009 | 01:13 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Did u ever get your light to work I am having the same trouble. The light works but no voltage. I wonder if there is a fuse for just that light somewhere that i am no seeing
Old Jan 11, 2009 | 01:33 PM
rriddle3's Avatar
2 year old thread and the OP hasn't posted since 4-08. Doubtful he will reply.
Old Jan 11, 2009 | 02:00 PM
mrafindley's Avatar
Sorry was just trying to use the search button instead of starting a new one didn't see when he last posted
vahn7ca
Mar 28, 2014 06:41 PM
nswoodsman
Aug 29, 2011 09:39 AM
mdehoogh
38
Jan 22, 2011 03:32 PM
shadysxz
Jan 26, 2009 02:56 PM
PAGuy77
Jan 17, 2007 10:40 AM
