All wired up...but problems
So I finsihed wiring it all up ... I have to ground the amp better because it kept going out...
Problem is it is very distorted! How do I adjust my settings for a better quality sound
I did the DMM 38.7V at the speakers for the gain
I have the X set at 80hz
and the bass boost is about half way up
What should my headunit settings be for the bass?
Any more imput would be great!
(One of my co workers kept saying buy a cap!!!! your ganna fry your amp! I seriously almost smacked him!)
first off, fix your ground. then play with settings! lift up the cover panel for the back seats. On drivers side, right next to the trim for the back panels, there is a strap that the seat is bolted to. there is a 19mm bolt that isnt really doing anything. take that off, sand it down to get to bare metal, and bolt that baby down.
just curious to as how you came up with 38.7 volts cause that is around ~750 watts into two ohms which im guessing with that amp. which would most likely not be a clean 750 watts. but what vc's on the sub? and no bass boost!
I did it with the link hillbilly posted
MY amp is rated at 750 RMS at 2 ohms = 38.7V
I was in a rush installing this so I grounded it in the jack area...bad idea !
One second i would have bass the next second I wouldnt!
Its a alpine type R 4ohm DVC
another MSPaint-saves-the-day picture...
currently my zx750.1 is grounded to [B] but i need to find a larger connector to fit around [A] which, i think, is the preferred ground
this would be looking in from the passenger side rear door with the seats folded down and the flap up.
