alpine mrp-m350 enough for...
Is it enough power to run an alpine type r 12?
or 2 12" type s' |
RE: alpine mrp-m350 enough for...
barely. just remember to not crank the gains to compensate for low power.
what would be a good solid amp to power the alpine type r or two alpine type s'
giving them enough power |
zx750.1 would work with either one type R 12 or two Type S
A person from crutchfield tol me that the alpine mrp-m450 would be great to run a type r so i think thats what im going to with
pdx 1.1000
well now thats 450rms to a 500 rms sub.
does 50 watts make a big difference? probably not. but that type r can handle way more than that. I would take the single R over 2 type s 12's. I would go with what hillbilly recommended and try to find a zx 750.1. Probably cheaper and more power. |
yes, under-powering a speaker is usually just as bad as over-powering it. People will turn the gain and bass boost up more to get it louder, leading to speaker failure.
my zx750.1 was $180 USD shipped. idk about that alpine
I thought over powering a sub is fine as long as distortion is left outta the picture.
distortion kills subs, not too little, or too much power. |
was that a refurb.?
that is cheap, alpines amps are nice, but seem pretty expensive when compared to others. dont get me wrong, I love my 501, but I payed almost $1 per watt retail. worth it? maybe.....if you really like fine tuning your system, the digi's were great. |
no it was new. i added all of the ebay auctionsthat werent "buy it now" to my watch list and watched and watched...
ORIGINAL: blazinloud well now thats 450rms to a 500 rms sub. |
I was talking about the mrp-m450.
and actually, its only rated for 400rms at 2 ohms. and i wouldnt call an extra 200 watts pretty over rated. ;) my sundown will do over 2200rms at .35 ohms.....thats pretty underrated my friend. |
ORIGINAL: blazinloud I was talking about the mrp-m450. and actually, its only rated for 400rms at 2 ohms. and i wouldnt call an extra 200 watts pretty over rated. ;) my sundown will do over 2200rms at .35 ohms.....thats pretty underrated my friend. |
*copy and pasted from Jacobs board*[/align][/align]results from the sundowns...
Test Vehicle.. mine.. 05 aveo.. RMS clamp and dmm, as seen in the 12" test session.. This testing includes recent results, and not so recent.. woofers used.. 2 Mags (1.9 dcr per coil), 2 FI Q 12's (1.4 dcr per coil) either used 1 sub or both of the pair for loads.. pure 60hz sine was used to tested.. just under audible clipping 1 amp, single 1000ca everstart maxx, factory alt 4 ohm nominal = 518 watts @ 88% efficiency (voltage fell from 14.3v, to 14.0v) 2 ohm nominal = 948 watts @ 85% efficiency (voltage fell from 14.3v, to 13.6v) 1 ohm nominal = 1510 watts @ 78% efficiency (voltage fell from 14.3v, to 12.4 volts .5 ohm nominal = 1615 watts @ 72% efficiency (voltage fell from 14.3v, to 11.8v) .35 ohm nominal = 1748 watts @ 67% efficiency (voltage fell from 14.3v, to 11.4v) amplifier was protection happy @ .35 with tones, and some music. IMO.. one 1500d should be limited to 1 ohm nominal use in factory electrical systems.. for the sake of the car.. not the amp now... to have fun with some juice.. 1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt 4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v) 2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v) 1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8 volts .5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v) .35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v) amplifier did fine @ .35 with tones and music with the added battery 2 amps strapped, with both batteries (for the sake of not typing it over and over... voltage drops from 14.3v, to 12.8 the entire test... lol 4 ohm strapped = 1900 watts @ 82% efficiency 2 ohm strapped = 3150 watts @ 72% efficiency 1 ohm strapped = 3740 watts @ 68% efficiency .5 ohm strapped = 4425 watts @ 65% efficiency .35 ohm strapped = 5415 watts @ 62% efficiency amps would only tolerate a VERY short burp @ .35.. [/align] -------------------- - Jacob Fuller - Owner, Sundown Audio - Associate, Stereo Integrity [/align]not in the manual, or on the birth sheet. but this testing is from the man him self in a real world situation, just the way it should be imo.[/align][/align]5400 watts from a pair of 1500 watt amps aint too shabby imo[/align] |
i kinda thought underrated (in pretty much any context) meant: better than they say.
in the world of amps and woofers i take it to mean: more power than they say idk :eek: |
I guess you could look at it that way.....
But some companies over rate by 50 watts, others by.....alot more. there are lots of variables when testing amps. |
So is the mrp-m450 enough?
cause theres one on ebay but it doesnt include a manual, 2 end caps, and hi-level input harness what are all those...besides the manual and can i get them easily for cheap? if the amp is good enough then thats great. im not looking to completely fine tune it as this is my first car and i plan to purchase a different one later on and then put all my time and effort into it now im looking for something that will get the job done and if its the 450 and the type r GREAT |
they will work fine together. make sure you wire that amp at a 2 ohm load.
ORIGINAL: otnietdehoooo i kinda thought underrated (in pretty much any context) meant: better than they say. in the world of amps and woofers i take it to mean: more power than they say ORIGINAL: blazinloud I guess you could look at it that way..... But some companies over rate by 50 watts, others by.....alot more. there are lots of variables when testing amps. ORIGINAL: AtreyuManiac So is the mrp-m450 enough? cause theres one on ebay but it doesnt include a manual, 2 end caps, and hi-level input harness what are all those...besides the manual and can i get them easily for cheap? if the amp is good enough then thats great. im not looking to completely fine tune it as this is my first car and i plan to purchase a different one later on and then put all my time and effort into it now im looking for something that will get the job done and if its the 450 and the type r GREAT the hi-level input harness is an optional line level converter built into the amp. If you dont plan on using RCAs to receive the signal, you must use the hi-level harness. If you plan on using RCAs, dont worry about it. The end caps are trim pieces to make the amp look prettier. Not necessary but helpfull. Not sure where you would buy them seperately. |
ummm, depends what voltage they're tested at too.......most are tested at 14.4.....some much lower.
my sundown is rated 1500@12.8volts all testing is not done the same. thats why they implemented the cea style. |
ORIGINAL: blazinloud ummm, depends what voltage they're tested at too.......most are tested at 14.4.....some much lower. my sundown is rated 1500@12.8volts all testing is not done the same. thats why they implemented the cea style. |
I ended up getting a brand new amp.....and it did not come with a birth sheet.
that is the man who designed, and built it, what other confirmation do you need? the results would still be very very close. and how would bench testing it be anymore accurate? thats as far from a real world situation then anything......do they compensate for box rise? dcr per coil, etc. the 3000d did 3200@1.33ohm@10.75volts. that was in house testing done at sundown audio done by the owner himself. and that was an ACTUAL ohm load. imo, sundown took an extra 3 steps when rating their amps. not to mention the 1500d can be ran all the way up to 17 or 18 volts, which also, is not in their ratings. |
