alternator help
i have a 98 blazer. I am going to have a 1000 watt amp for my sub. I am wondering if i sould get a new alternator. I am also wondering how many amps the alternator should be. Can anyone help me?
RE: alternator help
no, you wont need a new alt. Is that amp 1000RMS or peak?
RE: alternator help
It is 1000 watts RMS. So what u think? and should i defiantly get a optima yellow top?
RE: alternator help
have you done any research at all or are you just wanting to buy things because of hearing what other people have done? Im not trying to be a jerk. It just seems like you are just wanting to buy these things because of rumors. I would suggest doing research as to how electronics work (amperage, impedence, electrical flow) and then try installing your own system.
RE: alternator help
well not to be a jerk but i have done a lot of research and i am instaling my amp and sub right now. Its ok tho i see what you mean. I just had a few extra questions that i wanted a personal opinion on and thats why i come here to the forum.
RE: alternator help
I had my alternator rewound for a few extra amps 15-20... but it needed rebuilt anyways. I would suggest running 0/1 ga wire and upgrading the big 3. That should be plenty for 1000w amp on a stock charging sytem.
RE: alternator help
ok thanks a lot
RE: alternator help
im runnning a factory alt in my blazer atm with 1 4000d i get some pretty wicked voltage drop but no alt troubles u should be fine with 1000 with no upgrades i would deffinatly go with aught guage tho the big 3 is a good idea. dosent make a really big diffrence tho unless u get into some big power.
RE: alternator help
thanks again
RE: alternator help
:eek: If you are having power sags why not install a storage capacitor ahead of your amp to smoothout the sags?
| All times are GMT -5. The time now is 03:50 AM. |
