-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Amp? (https://blazerforum.com/forum/audio-video-electronics-8/amp-11691/)
DankBlazer 07-08-2007 01:35 AM
Amp?
I'm about to buy an alpine type R 10' off of www.onlinecarstereo.com, just not sure if I should get a 4ohm or a 2ohm woofer ( links of the two subs at bottom ), what's the difference or advantage of a 4ohm or 2ohm sub? Also not sure what amp to buy, the sub is only 120$, and i'd like an amp for under $175 that will push this sub nice, would also like to order it from the same place.. well if anyone has some good advice i'm all ears, that is the sub i am getting though, just need some help on an amp what which type R to buy, 4 ohm or 2 ohm, thanks, if i forgot anything i'll add it later
http://www.onlinecarstereo.com/CarAu...roductID=14953
http://www.onlinecarstereo.com/CarAu...roductID=14952
Adding:
Is this a good amp for one type R 10' 2ohm?
http://www.onlinecarstereo.com/CarAu...roductID=16338
[align=left] [/align]
blznlowxtreme 07-08-2007 11:21 AM
RE: Amp?
i think that that would be a good setup for good sound
blazinloud 07-08-2007 04:52 PM
RE: Amp?
that would work nicely, but i think you'd be better off with a class d amp, built for driving subs......
hillbillyinOhio 07-08-2007 08:56 PM
RE: Amp?
not a bad amp. get dual 4's and run at 2 ohms. I agree on getting a class D amp though.
DankBlazer 07-09-2007 02:42 PM
RE: Amp?
Do you have any suggestions on amps for just one 10' R?
hillbillyinOhio 07-09-2007 03:03 PM
RE: Amp?
Kicker KX400.1, ZX400.1. those come to mind quickly.
