-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Amp firewall pass through (https://blazerforum.com/forum/audio-video-electronics-8/amp-firewall-pass-through-100064/)
Matthew Nicholas Aug 11, 2019 02:53 PM
Having a hard time finding a spot to run the Power cable for amp through the firewall. I have a 2000 Blazer LS 4x4. Can anyone point me in the right direction?
Tom A Aug 11, 2019 04:14 PM
I had to run a couple of power cables in mine, and I ended up going through the floor and along the frame to the front. There just isn't a lot of room on the firewall.
I used some of to make the holes water tight.
blazen_red_4x4 Aug 12, 2019 06:44 AM
Depending on the gauge of wire you're trying to run, you can squeeze up to about a 4 gauge through the antenna grommet on the passenger side after you open the hole up a little. Just don't forget to seal it up with a little silicone afterwards, they're prone to leaking with just the antenna wire in it...
For my 0 gauge, I ended up running along the passenger side frame rail and came up through the floor under the rear seat via a drilled hole and a grommet I popped in place.
https://i113.photobucket.com/albums/...527_183733.jpg
https://i113.photobucket.com/albums/...527_183724.jpg
https://i113.photobucket.com/albums/...527_183829.jpg
https://i113.photobucket.com/albums/...527_192509.jpg
Ended up adding another fuse junction where it terminated under the back seat, which has worked out great because I've been able step it down to 4 gauge with some of the various amps I've had in the truck.
https://i113.photobucket.com/albums/...527_194622.jpg
https://i113.photobucket.com/albums/...527_194632.jpg
LesMyer Aug 16, 2019 08:45 AM
I took my power off the starter terminal, went through a waterproof fuse holder, and immediately went inside the frame rail to the rear - coming up through a grommet into the old Onstar module compartment where I mounted my amp. This was on a 2001 LT four door.
