Amp help!
Old May 4, 2010 | 03:13 PM
S10Blazerdude's Avatar
S10Blazerdude is on a distinguished road
Default Amp help!
I have a 1600 watt, 2 channel amp.....and i have 4 subs now.....is it possible to run 2 subs on one channel? So total 4 subs on that one amp? Would that be safe or would I need another amp?
Old May 4, 2010 | 04:59 PM
jlockEMT35's Avatar
jlockEMT35 is on a distinguished road
U can wire it and it will work, just make sure you are using proper gauge cable and a proper fuse. I would also invest in a serous capacitor or you will smoke your alternator. Why you would want 4 amps is beyond me but it is doable
Old May 4, 2010 | 05:00 PM
Capacitor! LMAO!! Please no...
Old May 4, 2010 | 06:51 PM
MTopper's Avatar
Well, it would help to know what amp you're running along with what subs. is your amp stable at 2 ohms stereo? are your subs 8 ohm, 4 ohm, 2 ohm, DVC, SVC?? not trying to be an a** but its easier to help when we have all the information
Old May 5, 2010 | 07:02 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Someone needs to take the time to look a few threads up and read THIS
Old May 5, 2010 | 08:53 PM
zedartwo's Avatar
Wow. I actually read it. Rolled over it a few times but the Bruins had a good lead so I thought I'd read it lol. I think I'm gonna take it easy on my system for a bit untill I have cash for a kenetix batt and better alt.
Old May 5, 2010 | 11:02 PM
MTopper's Avatar
I assume he read the original post wrong but.... really? anyways... Still waiting to hear what amp, what subs, and so forth so we can help the OP
Old May 6, 2010 | 01:16 AM
ImScrewed92's Avatar
Yeah really, Crutchfield and 12volt.com have wiring diagrams but like you waiting on the OP to respond... Caps... please get a HO alt or don't do car audio. Caps are like using tylenal on cancer and extra batteries will strain your factory alt also. The only real reason for a cap is if it's a show car and you want another light and a volt meter, thats it. Should be gettin my amp tomarrow. I swear I have a for a brain. lol.
Alright, Unless you have some weird subs like JL, your either 2 ohm or four ohm VC. And most subs are dual voice coils. So I'm gonna guess dual 4, slight chance dual 2.
If dual 2 ohm, make sure your amp is 2ohm stereo stable.
http://a248.e.akamai.net/pix.crutchf..._2-ohm_2ch.jpg
If dual 4 ohm, make sure your amp is 4ohm stereo stable.
http://a248.e.akamai.net/pix.crutchf..._4-ohm_2ch.jpg
If none of the above helps, give us some more info! ha ha...
Old May 6, 2010 | 08:42 AM
MTopper's Avatar
good call screwed. i just wasn't sure of what he has you know?
Old May 6, 2010 | 04:20 PM
Well I figure most subs are dvc. And since he has four subs. There's a chance they are 2ohm but more than likely are 4ohm. Most 2 channels amps are 4ohm stable bridged and 2ohm stable stereo. So I just threw out there the two most common scenarios of what I felt he would have. Car audio is my passion so yeah, I think about stuff like this alot. lol!
