amp to interior speakers
ok a few monthes ago i got into spl i was going to get two alpine type s with two 800 watt 2 channels but i found out that would make it run a meesed up ohm load so i got two alpine type Rs with two Vpower 1000 watt monoblock i was wondering if i tune the amps WAY down would i be able to split them instead of running one 4 channel
i hit 143.2 DB in an 01 eclipse i just got my jimmy cant wait to see what i hit |
RE: amp to interior speakers
So you have two TypeR's and a single mono amp? What are you trying to split and what exactly do you mean by "running one 4 channel"
ok, sorry for the poor english
i have two vpower 1000 watt monoblocks so two amps two subs i want to run my interior speakers off of two 2channel amps 800 watts each my question is would the 2 amps work on my interior speakers will this work instead of running a 4channel amp to my interior speakers |
yes. one amp use fro front l-r and one amp use for rear l-r
ORIGINAL: SPLjimmy ok, sorry for the poor english i have two vpower 1000 watt monoblocks so two amps two subs i want to run my interior speakers off of two 2channel amps 800 watts each my question is would the 2 amps work on my interior speakers will this work instead of running a 4channel amp to my interior speakers Your first post makes sense, I must have misread it the first time. Like vin791 said, it will work fine. one amp to the front doors and one for the rear doors. I don't know of any speakers that can take 400W though... |
2 two channels will work but why not just use 1 4 channel?? its easier to deal with and less wires
he already has the 2 channels i think?
and i'm guessing they're 800 peak 1 ohm and that's why he didnt have them pushing subs because not very many amps are 1 ohm stable. so 400 peak each channel 1 ohm. 2 ohm 200 each; 4 ohms 100w each. but thats a guess. what speakers you running inside? type s? |
ok i appreciate all your help im a newb with coaxel speakers heres the info on the speakers they are soundstream 3-ways[*]RMS Power (Watts): 150[*]Magnet Weight: 18 oz.[*]Frequency Response: 60-20k[*]Voice Coil Size: 1"[*]Sensitivity: 91db[*]Mounting Depth: 2.36"[*]Powder coated basket[*]Aluminum Coated Cone[*]Rubber Surround[*]BASV Voice Coil[*]Impedance: 4 ohm
here is the stats on the amps Features: MOSFET transistor outputs MOSFET Power Supply PWM Circuitry Full Selectable Crossover HI/Full/Low Three Way Protection Circuit 2-Ohm Stable Stereo Tri-mode Capable Variable Low-Pass 40 ~ 250Hz. Variable Hi-Pass 40 ~ 250Hz. Bass Boost 0 ~ 24dB. Subsonic Control 30 ~ 175 Kz. Frequency Response: 10Hz. To 30Khz. S/N Ratio: 97db. THD: 0.02% System Distress Indicator High/Low Level Inputs with Floating Ground Platinum RCA and Screw Terminal Connections Line output 150 watts RMS X 2 @ 4 Ohm Load 180 watts RMS X 2 @ 2 Ohm Load 360 watts RMS X 1 @ 4 Ohm Bridged 800 watts PEAK X 1 @ 4 Ohm Bridged so would it be 150 watts to each speaker? |
That is correct.
ok guys thanks a lot
| All times are GMT -5. The time now is 05:41 PM. |
