Big 3
Old Aug 10, 2008 | 08:04 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default Big 3
i did the big 3, i still get a nasty voltage drop what did i do wrong? the blinker still makes the voltage needle move around too.
Old Aug 11, 2008 | 03:57 PM
neo71665's Avatar
Default RE: Big 3
More info? What size wire did you use, leave or remove the factoy wire, didn't try to fuse the new?
Old Aug 11, 2008 | 05:08 PM
Numba1Sean's Avatar
Default RE: Big 3
used knukonceptz 4 awg which is bigger then other 4 awg. left factory wires installed, new is fused. checked all ground points today and all are good. one thing i screwed up with is left the power wire way to close to the heater core hose so i also fixed that today.
Old Aug 11, 2008 | 05:32 PM
neo71665's Avatar
Default RE: Big 3
Its only bigger cause the insulation is thicker and its finer strand but thats a side note.
Ditch the fuse, you don't need it. Make sure all connections are tight. What kinda ends you use, crimp, set screw, or solder?
Old Aug 11, 2008 | 05:45 PM
Numba1Sean's Avatar
Default RE: Big 3
side note thought of though, insulation is not thicker then others as far as strand im not counting it lol. i compared it to kicker and stinger stuff. are you sure about the fuse thing? connections are tight to the extreme actually. i used stinger crimp ends and they are really tight also.
Old Aug 11, 2008 | 05:54 PM
neo71665's Avatar
Default RE: Big 3
Yeah, different strands styles have different sizings standards. Soild wire is the smallest for it size, then thick stranded, and finally thin stranded will be thicker. All comparing to the same overall gauge.
The fuse is pointless, even if it blows both ends are hot and unless you check it often the volt gauge reads off the alt so you won't know it blown and it might leave you on the side of the road with a dead battery.
Old Aug 11, 2008 | 06:02 PM
Numba1Sean's Avatar
Default RE: Big 3
even with the stock wires still connected? im just confused as hell cuz alot of ppl say fuse it and when you upgrade the alternator you have to fuse it, but then some say you don't fuse it cuz its pointless power flows from both ends. idk man so many diff things ppl say
Old Aug 11, 2008 | 06:07 PM
neo71665's Avatar
Default RE: Big 3
Well its not really gonna hurt anything but pointless. If it makes you feel better leave it be just make sure you carry a spare fuse in the truck.
Old Aug 11, 2008 | 06:13 PM
Numba1Sean's Avatar
Default RE: Big 3
i have a 5 pack lol. so that aside what could be the problem? maybe it was a heat issue being so close to the heater core hose?
Old Aug 11, 2008 | 07:54 PM
neo71665's Avatar
Default RE: Big 3
I highly doubt its a heat related issue, sounds more like a connection issue.
Exactly what did you add and to where?
