Big 3 upgrade?
Anyone done the "big 3" upgrade in a 98 or newer blazer or jimmy? I just wanna make sure i'm not going to run into any problems.
I'm hoping to get mine done in the next couple months, I know lots have done it without issue.
I did the big 3 uprade on my 2010 Jeep JKU and will be doing the wifes 1995 Blazer next
0 gauge wire all around 0 gauge Battery Neg to body Ground 0 gauge Alternator Mounting Bracket to Body Ground 0 gauge Battery Pos to Alternator with 200amp ANL Fuse inline (fuse no more than 8 - 10 from the battery) |
Did it on my 01 with no issues
i've done it on a 87, 88, 91, 2 93s, 94 s-series, a 96 nissan hardbody, 81 honda accord, 78 nova, 79 camaro, and a 69 gmc with no problems.
alt charging post to + battery - battery to frame from that frame point to engine block (alt bracket), core support, and fender On my blazer i also ran a cable from body to frame in the rear cargo section. The bolt sticks in the cab and i use it as a lug to bolt my inverter, stereo amp, and cb amp - to |
Originally Posted by gadget799
(Post 534773)
i fused it on my JK because i upgraded my alternator to a 200 amp high output model but as for the blazer i will fuse it as well better safe than sorry consider it a little piece of security rather a $3 fuse blow than some other part that may cost waaay more ..
I can see your logic, I guess I was just questioning it since there is not a fuse there to begin with. But hey, extra added security.
there is a fuseable link in the original wires... Its in the wire its self.
hmm interesting, either way, when I do the big 3, its not getting a fuse. All the tutorials for it said its "NOT" needed LOL
| All times are GMT -5. The time now is 12:52 AM. |
