Bravada speakers and radio in a blazer
I was reading about the Oldsmobile bravada and i had read that they had better speakers or something. Is this true? If so could i take the radio and speakers out of a Bravada and put them in my blazer i know there is a Bravada in my local junkyard with everything still in it.
RE: Bravada speakers and radio in a blazer
Again, what year.
Problem is that the Bravada may have the Bose stereo system which includes an amplifier. This adds a lot of complexity to the swap including the wiring harness for the amp. |
I can only hope that the speakers will be bose. My blazer already has one 800 watt 2 channel amp and i think that will work wont it? oh and again the the Bravada could be a 96. What about the raido swap?
IMO, it is not worth the trouble. The Bose system really only sounds good when you have everything. Any good aftermarket equipment, IMO, sounds equal to and, in most cases, better than the factory Bose system.
ok and yeah you are right it would be too much work for just adding slightly above stock speakers.
| All times are GMT -5. The time now is 02:50 AM. |
