can I amp my 6x5's
I replaced all of the 6x5's in all 4 doors with pioneer 240 watt 6x5's. I also have a pioneer head unit also, if it helps. My question is can I amp all 4 6x5's to make them sound better. They get good bass with hard rock I listen to the most. The quality of the bass goes down as I go to techno. Not much, but less. Now rap is a different story. The bass sucks on rap. Can I amp with a pioneer 4-channel amp, and if I can, which one is recommended for this. Also, where would be a good place to mount the amp. On the flaps behind the back seats, because I'm going to do a 3-10' sub box right there. Can I mount them on the covers of the compartments in the back. I have my 6-disc changer in the right one. Thanks.
RE: can I amp my 6x5's
Find an amp that has the closest RMS wattage, to the RMS wattage of your speakers, for best SQ (I think so, anyway)
And pretty much any place that has room will work for the amp... The most annoying part is going to be running the wires... |
Yea, get a 4 channel amp.
6x5's? you mean 6.5" right........yes you can amp em, but dont expect too much bass......thats what subs are for.
I'd suggest a cheap alpine amp.....pioneer dosent make the best amps.......a 4 channel alpine can be yours for $140. you claim there 240 watt max? which means 120 rms which seems purdy high for coax. I think between 50-75rms per channel will be fine. Lots of ppl put their amps on the back of the seat......I have mine bolted to the back of the box......saves damaging the truck...... |
6x5's? you mean 6.5" right. Lots of ppl put their amps on the back of the seat......I have mine bolted to the back of the box......saves damaging the truck...... yes you can amp em, but dont expect too much bass |
O.k....um....I have mine pushed right up to the seat and i have never had a problem.....I wouldnt want to put them on top of the box....just more out in the open for theives to see.
sure ya you can put the amps their if you want, no probs. and once you get even 50 real watts on them 6.5"s you wont need to turn up the bass boost..... |
| All times are GMT -5. The time now is 01:23 PM. |
