can this work???
i am adding some mid bass drivers to my system and want them in the rear door stock location on my 2002 4 dr blazer, only problem is i did not realize when i bought the drivers that the mounting deptth is 3.5" and the rear door mounting depth is 2.329" (according to crutchfield). The drivers are ED EU 700's, the local installer tells me to make a 1.17" spacer out of mdf to make the depth but i do not have the tools to do it and am not sure if that large of a spacer will fit behind the stock door panel, cutting the door panel is NOT an option. any one know for sure if i can get an adapter/spacer and still fit behind the door panel?
just an update, There is no possible way, spacer or not that the eD EU 700's will fit in the rear doors, i took it all apart and it is never gonna happen. first off they would need at least a 1 3/4" spacer with magnet right on window track (which can not be moved or spaced, welded right to door frame!) secondly even with that much of a spacer, the door panel does not fit over the speaker, it sticks out about 2" or so so it would involve major cutting and glassin to work. I had to return the speakers. The EU 700's are 3.5" deep!! I am not sure how Hillbilly did it but it certainly does not work on mine...
ORIGINAL: jagblazer01
why isn't cutting the door panel an option?
lowloudnproud1
Sep 2, 2010 07:12 PM
ragu
Jul 13, 2010 12:08 AM
hantayo13
Jan 12, 2008 12:34 PM
neogeo92
Oct 8, 2005 03:19 AM
