Cannot Get Speakers To Fit
Old Aug 6, 2007 | 08:12 PM
982DRBlack's Avatar
982DRBlack is an unknown quantity at this point
Default Cannot Get Speakers To Fit
I purchased a set of MB Quart Component speakers for my door in my 98 2Dr Blazer and cannot get them to fit. The stock door brackets were of the wrong size and too flimsy, so I ordered these adapter brackets from Crutchfield http://www.crutchfield.com/S-TFziYbt...mp;I=120823043and the speakers do not fit in these brackets. I called crutchfield and the guy said they "normally work" I asked him if I had ordered a set of 6.5" speakers from them for the front would they have sent me those brackets and he said yes. The entire outside diameter of the mounting flange on my speaker is 6.5". Has anyone successfully mounted speakers of this size w/o a custom bracket? Thanks.
Old Aug 6, 2007 | 08:19 PM
hillbillyinOhio's Avatar
Default RE: Cannot Get Speakers To Fit
what size components did you get?? Just find a piece of MDF or plywood and cut out the diameter for the basket on the speaker and screw that thing to the door!
Old Aug 6, 2007 | 08:23 PM
982DRBlack's Avatar
I would but there has to be something that sticks out about 2 or so inches so that the back of the speaker doesnt hit the window channel. Worst come to worst ill make something.
Old Aug 6, 2007 | 08:50 PM
if you use 3/4 inch mdf, it should clear with no problem. that is what i did with my adire extremeis and they are about 4 inches deep. just double up the 3/4 inch and should be fine. or put the original brackets back on.
Old Aug 6, 2007 | 08:58 PM
982DRBlack's Avatar
Yeah that would work fine. I shall be doing that. Need MDF for the rear anyways. Thanks Hillbilly.
Old Aug 6, 2007 | 09:01 PM
no problem. doors are trick sometimes. I have a stack of mdf spacer rings that i keep stocked all the time. you would be surprised at how many cars have shallow door mounts! and I always flush mount the speaker in the top piece with a router
Old Aug 6, 2007 | 09:05 PM
982DRBlack's Avatar
Yeah, i thought they were going to be easy until the speaker didnt freakin fit. So thanks for the ideas and tips, they are greatly appreciated.
Old Aug 6, 2007 | 09:33 PM
blazinloud's Avatar
thats sounds nice hillbilly.......the flush mount would look oh so pretty. I bet those adires sound amazing.how much power you got goin to those anyway?
Old Aug 6, 2007 | 10:18 PM
you mean had? i sold them to my buddy when the blazer went away!
was powered by this , Zapco
they sounded amazing, but it took me a month and a half to get the crossovers right. had to be had built. not a project I will do again!
Old Aug 7, 2007 | 01:11 AM
blazinloud's Avatar
damn......you had some nice gear......after watching some vids of the SSX on roe, kinda wish I picked it up [8D]
but then again......I only have 1600rms on tap far cry from your 14k
prayerwimp
Jun 26, 2014 09:27 AM
kgkern01
15
Jul 23, 2011 11:17 AM
brock
Feb 20, 2009 08:25 PM
jdblazer
May 23, 2007 03:34 PM
jdblazer
Feb 4, 2007 11:45 PM
