cd changer harness
Hi,
I have the factory radio in my 2005 trailblazer (not bose, no XM, with Onstar) and just ordered the PIE adapter harness to allow me to hook up the Sat radio through the added inputs. Can anyone tell me the location of the harness I will need for the Aux CD Changer ? I had the kickplate on the passenger side off to run the antenna wire and saw 4 harness plugs there....and am hoping it will be that easy. Thanks for your experience. Jeffyr |
RE: cd changer harness
Are they similar? If none of them look alike, then no. You have to have the same amount of pin inputs as outputs.
I forgot to post an update.....here it is.
The PIE adapter worked like a charm. I did have to remove the stereo, but it was all plug and play. I managed to leave the factory harness connected too, in case there is a security code needed to get it going again. I now have input jacks that I can plug an ipod, or satelite radio into. This is worlds better than the FM modulator. Jeff |
| All times are GMT -5. The time now is 07:26 AM. |
