Circuit City install issue??
I picked my truck up about a week ago, haven't had it that long. The one aggrivating thing that it did was when you start the truck, the door locks locked. When you turned the ignition off, it unlocked them. The unlock part wasn't bad, but the lock part was bad if you start the truck to warm it up and shut the door without thinking.....
Today I decided to replace the OLD Pioneer radio that came in the truck. A CD was stuck in it...and I wasn't going to have any of that. Inded up getting a Sony with Bluetooth...I had CC install it.......well....NOW the doors don't unlock OR lock....also my stearing column cover is loose, which I am sure is a screw that they missed. My question is....could the door locks in any way have been tied in with the old radio....or is this all coincidental??? BTW this is a 1997 GMC Jimmy 4x4 4-door |
RE: Circuit City install issue??
locks arent tied in any way at all. My guess is a wire came loose or a fuse is blown. What all did CC install??
ORIGINAL: JediKnight2 ... The one aggrivating thing that it did was when you start the truck, the door locks locked. When you turned the ignition off, it unlocked them. The unlock part wasn't bad, but the lock part was bad if you start the truck to warm it up and shut the door without thinking..... i think thats called "rolling locks" and there is a way to disable it by turning the key on then off then press some buttons... etc...etc.... im not real sure on the procedure but someone posted a thread a while back explaining how to deactivate it. |
Yes, I posted the procedure some time back. Here's the thread.
Just sharing my CC experience.
I got 4 Polk speakers and a Pioneer mp3/cd player installed, they moved everything (I understand, to make the job easier for them) but didn't move anything back to the right spot. Other than that, they messed something up on the radio. I'll post a new thread for this problem. I have to get it taken care of anyway. |
They just installed the radio. The guy had the dash cover off, dropped the panel just below the stearing column....from what I remember that is about it...It was a big honkin insert they put in...but it is a BIG hole for the factory radio.
That wouldn't be a different fuse would it?....I mean the power locks still lock.
Well, they fixed my steering column cover, just a few tabs out of place. IN ADDITION, they figured out what the deal was with the power locks....come to find out I have an after market keyless entry system in the truck that neither I or my cousin knew about. Omega REC-11...now I have to figure out how to program it as it reset when the new radio was put in.
Upgrade to a nice alarm instead, so you know what's in there.
| All times are GMT -5. The time now is 06:41 PM. |
