control wire for amp
what color wire do I add the power control wire from the amp to the factroy deck.
RE: control wire for amp
Get a 12V test lamp. I don't know
mine is blue but it may be different. look for lettering on the wiring, you'll be looking for "rem" or the remote wire.
yes, it should either be blue or blue with a white stripe (depending on the harness). if your unsure, hook everything else up, then just run a wire over the seats and test which one works. and if none work (i.e. you dont have the rem wire for some reason), just hook it up to the ignition wire. its the same exact thing.
