-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   convert Radio wiring (https://blazerforum.com/forum/audio-video-electronics-8/convert-radio-wiring-102874/)
jimmy_for_ever Jan 21, 2021 05:40 AM
Hello everybody
I have question about the old style jimmy harness if it can be convert to the newer type which is come in Blazer/Jimmy 04-05 that come with double din.
My old style harness and the Radio
https://cimg1.ibsrv.net/gimg/blazerf...3451969f24.jpg
https://cimg2.ibsrv.net/gimg/blazerf...dc462615ec.jpg
https://cimg3.ibsrv.net/gimg/blazerf...30cf1aeb3.jpeg
The newer version harness and Radio
https://cimg6.ibsrv.net/gimg/blazerf...890c7f12f7.jpg
https://cimg5.ibsrv.net/gimg/blazerf...d96670f3a2.jpg
https://cimg4.ibsrv.net/gimg/blazerf...ef9f6de159.jpg
blazen_red_4x4 Jan 21, 2021 06:43 AM
Anything is possible. I made an adapter to convert the radio plug in my wife's Hyundai Elantra to the same plug on my 04 Blazer, so I can hot swap radios if I ever want to, plus getting aftermarket radio adapters is a lot easier for the Blazer's generic GM plug than the Elantra...
With the newer style, you really only need the larger plug. I believe the smaller one is for systems with Bose audio, which incorporates a stand alone amp and all, so I wouldn't even try to get into that...
But all you would need is the pinouts and a couple plugs to just make a adapter harness. I certainly wouldn't go hacking up the wiring in the dash just to change the plug...
jimmy_for_ever Jan 21, 2021 09:46 AM
Do you know where can I find male connector for the old style harness? So, I will be able to use the old harness and the new one without touching the original factory wires.
El_Beautor Jan 21, 2021 09:52 AM
It's important to note that the newer style radio you show are VIN coded to the BCM. They have to be program matched to the BCM by a GM Tech tool. You can't just plug one in and have it work. I'm not 100% positive, but I doubt the older style BCM can be programmed to use the newer style radio if that's what you're trying to do.
I think your project might be a lot more involved and difficult than just changing over the wiring harness and plugging in the new radio.
jimmy_for_ever Jan 21, 2021 10:29 AM
No, I already find a method to match the VIN coded using eeprom programmer
jimmy_for_ever Feb 2, 2021 02:07 AM
Anyone have the wiring diagram of Single din and Double din wiring diagram ?
thank you
LesMyer Feb 7, 2021 12:59 PM
6 Attachment(s)
thank you
here you go
jimmy_for_ever Feb 8, 2021 06:13 AM
Originally Posted by LesMyer (Post 731537)
here you go
Thank you very much finally I got it. But I have a question about the wiring harness both manual show 1999 and 2004 have same connector 12110088 but they are not ?
