curious enclosure question
I tried searching but no luck. For the audio experts on here-- I currently have a Premier 2504spl 10" sub in an enclosed box powered by a Soundstorm 1200 watt amp. I know everyone hates bass tubes, but I havnt come across anyone whos swapped the sub for their own. In other words-- If I put my sub in a tube will it sound like crap? Its out of curiousity.
RE: curious enclosure question
If its one of those prefab tubes yes it will sound like crap.
If your talking about a sonotube . you can get some pretty good bass. |
heres an example of one for an 8" AA Assassin with a 3" aero on the end
http://i130.photobucket.com/albums/p...o/000_0064.jpg http://i130.photobucket.com/albums/p...o/000_0065.jpg What you need is Sonotube (can be picked up at a lowes or home depot) Then you need to construct some MDF Baffles. Then matt and resin. Your set. heres the equation needed to calculate the volume v=pie(r^2)h |
wow thanks this might be a good/fairly cheap experiment
more questions-- please forgive my ignorance, Ive never tried this before
what if instead of the sonotube treated with resin, I use a thick pvc pipe and insulate it. Would that be rigid enough? also, how would I go about making baffles |
You prolly wanna still resin them for strength.
For the baffle just cut MDF rings. iirc this is what Scott Owens was using before he switched to the 6th order. |
