-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Custom 12" sub box help (https://blazerforum.com/forum/audio-video-electronics-8/custom-12-sub-box-help-63424/)
mattjphoto Sep 24, 2011 01:13 PM
I think I have designed a box that will fit in the back corner of my 02 4dr Blazer. There is a little space between the wheel hump and back corner of the tailgate. I just bought a Sony XS-L126P5 from my work for $20 so I thought making a box would be a fun experience. I was wondering if anybody knows where I can find the space required for a sub to hit properly.
coolasice Sep 24, 2011 01:40 PM
usually it's on the manufacturer's specs for the sub... comes in the box when you buy it... for yours the net volume should be 0.77 cu-ft.
http://store.sony.com/wcsstore/SonyS...set-153817.pdf
mattjphoto Sep 24, 2011 03:11 PM
Thanks I ended up finding the paper you were talking about underneath a piece of cardboard in the box. Here is my design I drew up and if I did the math correct its just over the recommended size. I made a cardboard mock up and it fit just fine in the corner. My wife doesn't mind if I have a sub but doesn't want to loose any cargo space.
http://farm7.static.flickr.com/6164/...29e83d1f_z.jpg
http://farm7.static.flickr.com/6179/...ca2da4db_z.jpg
coolasice Sep 24, 2011 05:33 PM
remember it's net volume, so the .77 is the volume after you subtract the volume of the sub itself. This is also for a sealed enclosure.... a ported one will need more volume. The second page of the spec sheet has the recommended size for a ported box..
