dash removal help!!
Old Apr 6, 2007 | 01:04 AM
GrEeNeyedBLAZERbabe's Avatar
GrEeNeyedBLAZERbabe is an unknown quantity at this point
Default dash removal help!!
Hey, im getting an aftermarket CD player for my Blazer. its an '03 and my b/f was gonna try and help me install it myself so i could save some money rather than have the circuit city roadshop crew install it. my question is tho, how do you remove the dash to install the aftermarket player?
thanks for any help!!!
Old Apr 6, 2007 | 01:18 AM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: dash removal help!!
The search function helps a lot....
No matter, here's a previous how-to thread written up on how to take apart a 98+ dash to install a new head unit. Good luck!
Old Apr 6, 2007 | 01:20 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
you have to take a total of 7 screws out to get to the radio. first find the driver's side I/P extension, it's the piece that has the park brake release handle in it...there are two screws at the top and two at the bottom that secure it to the dash remove these 4 and let the panel hang so you don't have to remove the park brake release and the insulator panel. once that is loose and pulled slightly down you will see two screws on either side of the steering column that are holding the I/P trim plate on (the trim plate is the piece that surrounds the cluster and the radio and HVAC controls etc..) remove those two screws and then straight above the steering column there is one more screw that points straight up remove it and then you can pull the trim plate out to release all of it's clips. Once you have it out disconnect the headlamp/foglamp switches and then the rear wiper switch, 4x4 switch and the passenger's air bag on/off switch. now you're ready to remove the trim plate.....if you have a column shifter, turn the key on and drop the shifter into low gear for more clearance to remove the plate.
Old Apr 6, 2007 | 01:30 AM
Nice writeup.
Old Apr 6, 2007 | 01:35 AM
Thanks for the fast replies guys!! You rock!! i dont have my radio just yet, im getting it tomorrow, but your info helped me out. sorry for being a complete n00b [sm=chairshot.gif]- but thanks again!!!
Old Apr 6, 2007 | 02:14 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Also, don't forget. When you start to pry the dash cover off near the radio, you can reach behind the 4wd switch (if you have it) and intermittent wiper switch (if you have it) and pop them out towards you. This makes it a hell of a lot easier to disconnect the plugs they are connected to. When they are off, the hardest part is pulling the whole thing forward and up (to get around the shifter, if you have a column shift truck) When you do it once, the 2nd time takes about 5 minutes Good luck, I'm in the process of replacing my aftermarket unit which just crapped out, so I have to do it again today too...
Old Apr 6, 2007 | 03:20 PM
hillbillyinOhio's Avatar
why do you have to take out entire dash to replace the unit? 99 percent of aftermarket units have quick release's on the side. then its just a matter of sliding unit out and unhooking the wires.
a nice indepth how-to on removing dash for putting in a cd player is here. it is a PDF file, so make sure that you have adobe reader at least.
Old Apr 6, 2007 | 03:57 PM
nai0013's Avatar
nai0013 is an unknown quantity at this point
Hope you bought a dash kit and wireharness to put your HU in. Maybe a radio adapter? Stuff you can get at local stereo shop or wally world...if your a person who shops there.
Old Apr 6, 2007 | 04:41 PM
vagnozzi's Avatar
Hillbilly, my headunit has brackets on that side which bolt into the headunit cage which is attached to the install kit, so I really have to take it off again to put a new unit in the old cage
White954X4
Oct 6, 2009 05:39 AM
bbt8831
Sep 24, 2009 07:08 AM
Red96
Jun 17, 2006 02:20 AM
BlueBlazzin
Dec 17, 2005 02:54 AM
FarkDaNarc
Nov 16, 2005 05:08 AM
