dose not work
so i was going down the road and my musick just up and cut off. my set up is alpine hedunit with 6 rockford spekers and 2 12in kicker subs powred by a rockford amp. i check all fuses all wore good. i disconeced the subs and put the stock head back in and it still dose not work if i try to turn on the headunet then my gagse dye and i dont know how fast i am going. PLEZ help i have cheked all wiring and i still dont know what is rong. I NED HELP PLEZ
RE: dose not work
might be grouding out somewhere........
Pull the HU out. look for exposed wires! |
RE: dose not work
i puled out the hu and checked it but it was fine
RE: dose not work
take your alternator to your local auto parts dealer and have them test it i had the same problem in my 90 blazer and ended up gettin a new one and it fixed it u may even have to get a more powerful alt depending on how much electronics u have and mabey even another battery hooked up but i dont think you need to go that far
RE: dose not work
i alred put a brandnew batteryn in it. i think that i will just take it to my shop.
