Double Din
I Have A SSL DD888 i want to put in my 2001 blazer but its taller than the stock hole from the original stereo what do i need to do to make it fit
2 Attachment(s)
A hacksaw and the guts to cut up your dash.:icon_dance-disco:
https://blazerforum.com/forum/attach...ine=1388755924 Did something like that few years ago: click here to see my handywork at showyoursound.nl :icon_steer: |
Later Blazers have a double DIN facia for the dash. Grind not cut the frame of the dash with a dremel or die grinder as it only takes a little. There might be clearance issues to the rear at a heater duct. That can be remedied with a heat gun and a gentle push. Again only a little as there are other heat sensitive parts around. Remove air bag fuse and disconnect battery first. The adapter jack rattles around so rap it with a little foam. Good luck, now get after it!
I used the dash from a 2001 Bravada for my double din install. Everything matches up the same, just has a bigger opening for the stereo. No cutting or trimming was needed.
| All times are GMT -5. The time now is 07:23 AM. |
