Factory Radio Mystery/Question to all the Blazer pros
Hey people....I have a 2000 Blazer LT with a factory radio. (see pic) The radio has SCV (speed compensated volume) and I can't figger out how to get it to work![:@][:@] Ive tried the owners manual and have had little luck with it![:@] I know that there is an adjustment dial right below the main volume knob,I've turned it,but it doesnt seem to help. Also....right above the volume (slightly right actually) is a little light indicator that I think MAY have something to do with it. This little light NEVER seems to come on, even when I pop in a cassette or C.D..
Is this litle light an indicator that the SCV is on? Any help would be appreciated! Thanks.....................Rich http://image1.frappr.com/pix1/i/2009...c3c0_large.jpg |
RE: Factory Radio Mystery/Question to all the Blazer pros
The light is for the Theft-Lock, if it's not activated, the light won't come on.
I drove my mom's and brother's trucks with the SCV and never noticed a difference on either one. |
From the owner's manual:
SCV (Speed -Compensated Volume): With SCV, your audio system adjusts automatically to make up for road and wind noise as you drive. Set the volume at the desired level. Turn the control ring behind the upper knob clockwise to adjust the SCV. Each notch on the control ring allows for more volume compensation at faster vehicle speeds. Then, as you drive, SCV automatically increases the volume, as necessary, to overcome noise at any speed. The volume level should always sound the same to you as you drive. If you don’t want to use SCV, turn the control all the way down.The directions are clear. The important part is, 'The volume level should always sound the same to you as you drive.' If the SCV is working, you won't notice an increase in sound level, you simply don't hear any loss in level due to outside noise. |
Okay....that answers the little light mystery!:D
But how about the SCV? I'd like to be able to use it....but I can't seem to turn it on!:eek: |
if you look at the volume nob it has a tab off the left side if you flip it all the way down it is on if you want to know if it works take a driver and mash the gas if the volume gose up it is working i have a 1999 yukon has the same thing hope this helps
ORIGINAL: needshocks if you look at the volume nob it has a tab off the left side if you flip it all the way down it is on... |
sorry you are right i was not thinking it dose have to go up
| All times are GMT -5. The time now is 01:30 AM. |
