-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Finally buying amp (https://blazerforum.com/forum/audio-video-electronics-8/finally-buying-amp-18300/)
blazinloud 03-15-2008 06:49 AM
RE: Finally buying amp
no, are they dual 4 ohm, or dual 2 ohm coils?
since they're 15's go with at least 800 each....
dimmuborgir6nik6 03-16-2008 02:26 AM
Got any amps for that in recommendation?
blazinloud 03-16-2008 01:33 PM
http://www.onlinecarstereo.com/CarAu...roductID=19395
http://www.onlinecarstereo.com/CarAu...roductID=17085
http://www.onlinecarstereo.com/CarAu...roductID=17702
http://www.onlinecarstereo.com/CarAu...roductID=14333
or check out woofersetc.com they have a better selection...but dont ship to the great white north [:'(]
dimmuborgir6nik6 03-16-2008 08:43 PM
That first Hifonics you posted looks pretty good. After my next paycheck I might buy that one!
Good selections though, thanks.
bobditts 03-17-2008 11:30 AM
what is the final impedance do you need on the amp? you need to know that before even thinking about any amps. Second, it will be easier and more feasable to buy 2 seperate amps instead of one huge amp that will be very expensive. Third is where will you be installing the amp/s? you need to know how much room you have to work with. MOST IMPORTANTLY though is will your current electrical setup allow you to power all the amps you need?
blazinloud 03-18-2008 10:27 AM
$300 for nearly 2000rms is expensive?
bobditts 03-18-2008 11:37 AM
Which amp produces a legit and clean2K RMS for only $300?
blazinloud 03-19-2008 01:10 AM
Well the one I posted claims [email protected] for $340
maybe they mean on 16 volts :D
bobditts 03-19-2008 06:14 AM
I wouldnt believe it until I saw the actual test results. If it sounds too good to be true in car audio, it usually is ;)
blazinloud 03-19-2008 11:02 AM
thats true, but even if it was over-rated 400 watts it would still be a good deal.
afterall the 1606 isnt that overrated
I should mention that the amps i posted are if you bought dual 4 ohm subs.....you want to run those amps at 1ohm
