Flip-out screen reciever?
I have a 96' 4 door blazer. has anyone installed a flip out dvd/cd radio reciever? something like this:
http://www.crutchfield.com/p_070VD81...81.html?tp=448 when the screen flips out, would it hit the shifter (in an automatic)? thanks |
as far as i know that should install just like any other aftermarket HU, the only difference would be wiring so that the dvd works while ur in drive (if you choose to do so) and ur also have plenty of clearance between the screen and the shifter.
i know when the screen is up it souldnt hit anything but when the screen slides out of the reciever and retracts back it will it hit the shifter?
idk u might just have to get some measurements and see how everything lines up, i think u should be fine but just measure evrything out to make sure.
if it does put it in drive or something, pretty easy solution there.....
