Halos
I now have matching halos. I replaced the LEDs in the fog light halos (which were switchable between red and blue) to white to match the halos in the headlights.
Sorry about the crappy image. Camera Phone.
I also stuck some APC bluebulb/whitelight 194s in the headlight signals...
ORIGINAL: blznlowxtreme
thats awsome, is there a kit to buy or did you do it custom?
I see the light bar in the cowl strip. I am going to do that too. I also am going to put one on behind the front grille when I get my grille inserts. That would look pretty sick Euro. A white neon bar behind your grille. I would put it down below so you can't see the bar from the front, just the light shining out. I'll have to look and see if there is a place you can mount it. Back when I did mine, I just used a couple of cable ties around the radiator support and wired it in to a rocker switch on the inside. I had a floor shifter and three rocker switches right there. One was for the neon bar on the grille, one was for the red lights on the bumper and the liscence plate frame, and the last one was a neon bar behind the cowl strip. Man I miss that car. I am going to buy a beat up one for a project car one of these days when I have my own place and hopefully a garage. (Wakes up from daydream) What? Oh well.
****Edit*** OOps, I checked the pic again and saw it was at the front of the engine bay. Sorry. In the night pic, is your hood closed or is it open. If it's closed, taht looks pretty sick with the light shining out of the crack in the hood.
