Head unit wiring diagram
I need a wiring digram for a 1989 S10 Blazer, and if someone know which one goes where on a jvc deck that would also help. thanks
RE: Head unit wiring diagram
Constant 12V+ Orange
Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue if you buy the wiring harness, metra part number 70-1677-1 you should just have to match them up. the second (small plug) goes into the small plug ght will be behind the cig lighter. just make sure that the orange is plugged inline with the yellow in the harness, if you are gng to hardwire it, let me know, can give you the exact connections(not recommended) |
yea im gonna hardwire it because the person who had it before me already hardwired a few of them and i dont know where they go know. so if it isnt any trouble could you tell me the exact hookups to the deck. thanks.
