Help 2 15s
Old Nov 24, 2011 | 07:48 PM
  #21
2003_CHEVY_BLAZER's Avatar
2003_CHEVY_BLAZER is on a distinguished road
Dang I really appreciate it I know it can only be as wide as the wheel wells and but I gotta measure how longth the depth is cause I made an amp rack that takes up a little bit of room so I'll measure it tonight
Thank you
Oh and there 2 15 kicker cvrs
Old Nov 24, 2011 | 08:45 PM
  #22
MTopper's Avatar
i have a 2wd 2 door. i have a different width than you do. so i need all of them. also, are you looking for getting loud as possible or what? plus, what amps are you using? i can integrate them into the design.
if possible snap some photos of your current setup so i can get an idea ya know? I designed a box setup for Sturg on here a while back and also did my whole trunk layout for mine.
Old Nov 24, 2011 | 11:29 PM
  #23
j89lumaye's Avatar
j89lumaye is on a distinguished road
IF one is hitting up and ones hitting down, im pretty sure you have one hooked up backwards. If you switch positive and grounds theyre gonna hit a different way. We got my friends 2 12s hooked up backwards because they pound 2x harder that way and its been like that for almost a year now
Old Nov 25, 2011 | 01:09 AM
  #24
MTopper's Avatar
i just went back to your original ohm reading post. 3.4? why so high? 2.2 makes sense but 3.4? try taking the subs out of the box and reading the terminals on the sub itself. try this
terminal 1 +
terminal 1 -
terminal 2 +
terminal 2-
plug the positive lead of the meter in terminal 1 + and negative in terminal 1-. record your reading.
then plug positive lead of meter in terminal 2+ and negative 2-. record reading
then try 1+ and 2-. record it.
then lastly try 1+ and then 2+. record it and come back with those.
Old Nov 28, 2011 | 09:14 PM
  #25
everythings wired right im 100 % sure its the box because the other box they were in cracked it
these are some pictures i dont have the measurements yet ive been pretty busy im sorry
all the wires are covered now
Old Nov 28, 2011 | 09:20 PM
  #26
coolasice's Avatar
coolasice will become famous soon enough
its a ported box... the box would not cause the sub to extend out... there's a problem elsewhere.. test the individual coils as MTopper said.. but more likely your deck is introducing a dc voltage somewhere...
Old Nov 28, 2011 | 09:23 PM
  #27
hmmm i know like if i turn the subs off on the deck but have the bass remote up and the volume low it makes a faint popping sound when the bass would normally hit?
Old Nov 28, 2011 | 10:33 PM
  #28
MTopper's Avatar
check your radio's ground and your amps' grounds. i had to relocate my radio ground from the stock harness to the airbag bracket because i was getting a turn on/off pop through my sub plus, my amp had to have a better ground due to issues with a constant whine through the system.
Old Nov 28, 2011 | 10:40 PM
  #29
i will proly tomorrow night.
and i replaces the 1 amp that was in there a pioneer and i replaced the deck like 2 years ago it could be the wiring or the deck. i hope it is cause the subs and the amp is 1 month old. the rocksford frostgate amp for my door speaker is bad so i have all the wires running to the rear channels just to get buy for a little bit longer.
jandd4fun269
Lifting Tech
13
Apr 11, 2011 12:20 PM
ZeroShade0
Feb 25, 2009 12:41 PM
keyonn
Feb 14, 2009 08:17 PM
