Help with installing speakers!
I have a 99 4dr blazer and would like to install 6x9's in the front and back, but have no idea what to do. The haynes manual has an older blazer than mine and the directions don't work on mine. Any advice would be greatly appreciated!!! Thanks in advance.
RE: Help with installing speakers!
6x9's will not fit in either front or rear door without MAJOR work.. Not worth any effort to even think about it. Replace them with 6.5" components in the front and 6.5" in the rear.
yes, i second that. 6.5 components auxilary amped will sound 100X better than 6x9s. and wont require any mods
Sorry guys, I meant 6.5's. I got the screw off the door handle and the two bolts under the arm rest. Does the door panel just pop off after taking them off??? Is it just clipped on??? Thanks for the help!
Yes, pull away around the bottom.
Thanks catalin!!!
On my 97 2dr whats in the back? 6.5 or 6.9? I have not opened it up yet but was thinking of just putting some sony but if your saying components sounds better than I might go with that. Which ones in particular are you talking about.
ORIGINAL: ivannj On my 97 2dr whats in the back? 6.5 or 6.9? I have not opened it up yet but was thinking of just putting some sony but if your saying components sounds better than I might go with that. Which ones in particular are you talking about. |
The two doors.... errr SIDE PANELS have 6x9's in the back. yeah that's what I meant to say. :)
ORIGINAL: catalin The two doors have 6x9's in the back. |
Definetly look at components for your front of your vehicle. Additionally, you will need to make a spacer to place on the factory speaker mount, in order to properly allow enough room between the speaker and the window.
I would recommend mounting the tweeters in the dash. On the 2-door models, there is a stock tweeter mount in place of the 4X6 in the dash. That is a perfect mount for a tweeter, as it fires along the windshield and will give you good imaging and staging. If your vehicle doesn't have these plates, I would recommend looking at a bone yard or talking to a dealership to get these. Your car will sound much better with these plates. Hope this helps!!! |
