Help me choose a pair of components
The car is a 2001 s10 chevy blazer 4dr equipped with bose from factory. I have an after market head unit pioneer p4000 ub and an amp for the components that I am going to buy. The amp is a Cadence Xa 125.2 the amp puts out 120 watts at 2ohm and 80 at 4ohm. I would like to buy some decent sounding components for my front door pannels my prica range is $100-$200. I must buy the components from this website:
http://www.woofersetc.com/index.cfm?...roduct_ID=6201
Since I have store credit. I would really appreciate if someone can guide me towards the correct route with something that would fit. Does anyone know the measurments of the depth of the door pannel? If you have aftermarket speakers/components what are you using brand/model would be great. What is the biggest size spacer that I can use on the front door pannels? Thanks.
This will not be too much help as I am not a sound guy (read on and see) but I can tell you that something as bulky as JL VR650CSI WILL fit your fronts, but are too damn deep to fit the rears without modification.
*BONUS: the metal you have to remove in the rears to make those 6.5's fit holds the rail your windows use to move up and down. Ask me how I know...
So you are possivily sure that those JL VR650CSI will fit the front door pannels? Im not worried about my rear door pannels. Btw: What is the sound quality on those JL VR650CSI is it worth the money or can I find something similar for a cheaper price. The components will be amp'd by a Cadence amp 120 watts at 2ohm and 80 watts at 4ohm.
Mine are well worth it. i have a POS TiS 5 channel pushing my doors, and they freakin' scream!
yes they will fit fronts NP.
Worth it... well.... You can get the same sound quality for much MUCH less. It's up to you. Just stay away from cutting doors...
what brand/model components have the same quality for much less money? but they must fit the front door panels with no modification,if anything ill throw in a spacer if i have to as long as it clears the door panel.
The JLs
These save $130 <-- 2 pairs for 1^^^!
Saves $180 No prog corssovers but c'mon... Do you even need em?
Saves $130 ...
etc...
Saves $130 ...
etc...
