How to wire my system?
Some questions about my system:
-When running the power wire from the battery, where can I sneek it in through the firewall? -How do I get the side floor pillars up to run wires? Thanks! Chris |
RE: How to wire my system?
the antenna gromet is above the pass floor area. about where you left foot would be. Pull back the top of the carpet and its right there. adn the kick panels will just pull out. remove the sill panel and then just pull. The rear you cannot really pull them off, well you can on the top piece in a 2door. Just remove the two seatbelt bolts and youc an loosen the panel, and run your wires up through there
