I having amp troubles
I got a visonik v217sx Each time the bass thumps and/or i turn the music up the amp goes into protection mode and then cuts out (no power or protection led ) but when i goes out use my volt meter im getting no signal from the remote wire and my power wire well its not the amp i had a old amp laying around and it was doing the same thing any suggestion bad ground http://www.caraudioforum.com/vbb3/im...s/confused.gif bad remote http://www.caraudioforum.com/vbb3/im...s/confused.gif should run the remote to fuse box http://www.caraudioforum.com/vbb3/im...s/confused.gif but i just starting happing after replace the radio(Pioneer to a Panasonic) do you think i just hooked up the wrong remote wire it was working fine with the pioneer[/align] |
RE: I having amp troubles
try this, take a small piece of wire, strip off both ends, put one end into the remote, and the other with the 12v battery line. then if it cuts out, you either have a bad ground, the impedance from the subs is too low for the amp to handle, or the amp is bad.
if it plays fine, pull out the deck and check voltage on the remote. worse case scenario, run to the fuse panel . |
mine done the same thing when i re-wired my blazer with 4-gauge, and my ground had slipped out of the connecter but was still rubbing the frame, and everytime i tried to turn it up it kicked into protect
