installing component speakers
getting ready to install my 6.5" jl xr and vr components on my blazer. how do i get the old speaker grills off and where would you say is the best place to install the tweeters? i have 4 door so i need tweeter placement on front and back doors
RE: installing component speakers
I would recommend installing the tweeters in the A-Pillar firing along the curve of the windshield. If fabrication is not your cup of tea, you can go the the dealer and buy the tweeter mounts that go into the 4x6 locatoin in the dash. These are the plates that are OEM in the 2-door blazers.
As far as the rear components, if you can install them as a coax, that's pretty much the best. Rear components are a waste of money in my opinion, as I set up cars to recreate a concert. Every concert that I go to have the band in front of me, hence my vehicles have the music appearing to come from the hood. Hope this helps!!! |
i bought components for the back doors but i can make them coaxial. i just have to buy the adapter plate for it. thanks for the input
i say install the tweets in the a pillars facing directly at you, but only if you have the capability to back them off a couple dB. your supposed to keep the tweets as close to the mids as possible, but if theyre at the bottom of the doors, sometimes it wouldnt be loud enough. this is the best way to setup your comps to sound natural.
What's wrong with using the factory tweeter mount plates? Seems to keep it up in front of you allright.
well it all comes down to how it reaches your ears. and a direct path will sound most natural (for highs). i personally woldnt care if they were in the dash. im not too picky with that kind of stuff. but what i was saying above is that to technically achieve the most accurate and natural highs, place the tweets as close to the mids as possible but make sure they face directly at you
ORIGINAL: FatRyan well it all comes down to how it reaches your ears. and a direct path will sound most natural (for highs). i personally woldnt care if they were in the dash. im not too picky with that kind of stuff. but what i was saying above is that to technically achieve the most accurate and natural highs, place the tweets as close to the mids as possible but make sure they face directly at you Additionally, the rule about keeping the tweets as close to the mid as possible is an old tale. That actually doesn't apply in building a car system. I used the stock locations for my mids and my tweeters in my '99 Eagle Talon and had the 3rd highest sound quality at the 2000 IASCA Finals. Just thought I'd add my $.02 worth. (edited cause I can't spell) |
ORIGINAL: audiophyl ORIGINAL: FatRyan well it all comes down to how it reaches your ears. and a direct path will sound most natural (for highs). i personally woldnt care if they were in the dash. im not too picky with that kind of stuff. but what i was saying above is that to technically achieve the most accurate and natural highs, place the tweets as close to the mids as possible but make sure they face directly at you Additionally, the rule about keeping the tweets as close to the mid as possible is an old tale. That actually doesn't apply in building a car system. I used the stock locations for my mids and my tweeters in my '99 Eagle Talon and had the 3rd highest sound quality at the 2000 IASCA Finals. Just thought I'd add my $.02 worth. (edited cause I can't spell) |
It's hard to say which theory is correct but I have a different take on both sides of the argument. I would say the A pillar is a bad idea b/c higher frequencies travel faster than the lower ones and therefore a tweeter aimed directly at your head, that close, would hit you with it's sound way before the mids in the doors or the sub(s) in the back. Now yes it is milliseconds or whatever and no most of us couldn't hear it but...its like heardoom...you know it's there. The dash idea requires no modification if he already has the plates for it and that alone is enough reason to do it that way. At least it was for me.
ORIGINAL: HCCAFan It's hard to say which theory is correct but I have a different take on both sides of the argument. I would say the A pillar is a bad idea b/c higher frequencies travel faster than the lower ones and therefore a tweeter aimed directly at your head, that close, would hit you with it's sound way before the mids in the doors or the sub(s) in the back. Now yes it is milliseconds or whatever and no most of us couldn't hear it but...its like heardoom...you know it's there. The dash idea requires no modification if he already has the plates for it and that alone is enough reason to do it that way. At least it was for me. Additionally, I would recommend going to a sound off and listening to some of the cars. I can give you a list of vehicles to listen to if you want. Have fun! |
| All times are GMT -5. The time now is 05:26 AM. |
