keyless entry is it equipped or not
recently purchaced a 2000 blazer previous owner only gave dealer the 2 keys no remotes how can you tell if this vehicle is equipped with this option
RE: keyless entry is it equipped or not
if you look at the rear hatch button. if it has no key hole then it is equipped and if it does then it usually is not
eBay has a bunch of people who sell replacement remotes. There is a procedure to sync the new remote to your car.
You may already have the RKE (Remote Keyless Entry) module installed. It should be located above the DLC (Data Link Connector). If you have RPO code AU0 (A U Zero), then you already have the RKE module and a previous owner must have lost the remotes (check inside the glove box). If you do not have RPO AU0, then look around in the junkyards for a blazer with it, and pull the RKE module and possibly 1-2 ft of wire after the electrical connection to the RKE module. I believe that if you have power locks, the RKE wiring is there, but I have been wrong before.
Here are two threads on this subject (search function works...): keyless entry fob Adding Keyless Entry Good luck and let us know if you need any more information. |
IIRC my truck has remote keyless entry, but still has a keyhole in the back. But could be because my truck is an older model, I'm not too familiar with the newer models....yet.
In all the numbers in the glovebox I see AU0..... So I guess that means yes. Where is RKE module located in my 1995 4dr blazer....? Thanks ahead
see my post on RKE in the diy section
is anyway that i can check it
some numbers in the glove box been faded 1GNCS18W12K105182 |
| All times are GMT -5. The time now is 08:33 AM. |
