LH FWD speaker cuts out
My left foward speaker, in the door, randomly cuts out. Is this just bad wiring, or bad speaker? I don't really wanna go tearing through my door panel to figure it out if it's just a bad speaker.
RE: LH FWD speaker cuts out
The connection might be loose to the speaker. Try to open and shut the door to see if that works.
sure osunds like bad wiring to me but it could also be a speaker gng out. sorry, only way to know for sure is to pull panel off.
I've done the ole "beat on it while driving" thing. Guess I'm just gonna have to pull it off. Hopefully it'll be a bad speaker, gimme an excuse to buy new ones.
Yea the stock speakers suck anyways. When i get my car new in 01 i ripped those speakers out within 5k miles.
The door panel romoval isn't so bad. There are one ortwo 7mm hex-head screws under the solid handle, you'll need deep sockets and maybe an extension to get those, then the phillips screw behind the latch handle. Other than those it's all christmas tree clips and the top of the door (by the window) wraps around the metal of the door. Put your window down so you don't scratch it and pull the panel away starting at the bottom, then lift it up.
If you know how to solder wires to tabs it would be a good idea (if they're actually loose) so you don't have to rip it apart again. To put the panel back on just do that stuff in reverse order paying special attention to the top of the panel that goes near the window. |
ORIGINAL: TheBrettster Yea the stock speakers suck anyways. When i get my car new in 01 i ripped those speakers out within 5k miles. |
| All times are GMT -5. The time now is 01:18 PM. |
