MDF thickness and sound....
Old Mar 17, 2008 | 12:36 AM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default MDF thickness and sound....
I've noticed on my last few box builds that if i use a double MDF face (double 3/4"), it ends up sounding different than single face. Am I hallucinating or does the thickness of the MDf actually change the sound? Anyone with experience please chime in.
Old Mar 17, 2008 | 02:30 AM
if6was9's Avatar
if6was9 is an unknown quantity at this point
Default RE: MDF thickness and sound....
It may due to being a denser material. MDF typically has a density of 600-800 kg/m³. I haven't seen double MDF, but have seen HDF (high density) which is 600-1450 kg/m³. Is the double sided a sandwiched laminate? If so, the different densities and epoxy will effect sound, vibration and strength.
Old Mar 17, 2008 | 09:33 AM
dbleon's Avatar
Double thickness is just two pieces of 3/4" glued together...
Old Mar 18, 2008 | 11:44 AM
dbleon's Avatar
anyone?
Old Mar 18, 2008 | 06:38 PM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
the box is more sturdy and doesnt flex as much so it helps
Old Mar 18, 2008 | 06:42 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Usually 1" or doubled up 3/4" MDF is used on enclosures that house very powerful subwoofers that have the ability to flex the wood which can in turn create negative pressure resulting in loss of sound...Insternal bracing is something that is also used to aid in the correction of this problem. Like 'If6was9' said, density and bonding materials can also effect the sound....Unless you are very experienced and have a very tuned ear for bass this is not really noticable...
Old Mar 18, 2008 | 06:56 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
the denser the baffle is, the better it will sound. simple as that. Think of it as mounting a piece of paper vs. mounting the same speaker to a piece of thick cardboard. One is obviously easier to bend.
Old Mar 18, 2008 | 07:21 PM
dbleon's Avatar
I am going to put the same sub in a single baffle enclosure of the same ft^3 just as a test. I will let you all know.
Old Mar 19, 2008 | 01:11 AM
blazinloud's Avatar
Try 1/2" stainless steel
Old Mar 19, 2008 | 02:32 AM
mdehoogh's Avatar
ORIGINAL: blazinloud
hehe
