MDF thickness and sound....
Old May 4, 2008 | 10:52 PM
splblazer's Avatar
splblazer is an unknown quantity at this point
Default RE: MDF thickness and sound....
steal works great with concrete behind it. no flex at all.
kinda hard to awnser your question with out knowing your setup. what are the demensions of the box and what kinda power and woofer?
Old May 7, 2008 | 08:48 PM
Butts's Avatar
Butts is an unknown quantity at this point
More internal bracing is just as good as thicker MDF. Don't use anything thinner than .75".
Old May 7, 2008 | 11:49 PM
El_Beautor's Avatar
Normal MDF will still breath a little when its untreated (ie: no paint or resin). Try putting a piece on top of another, then putting a good shopvac to the top one. Even at 3/4" you can usually still pick up the bottom piece. Doubling up the sheets will reduce this breathing, and depending on how much glue you use between the layers that may also be acting as a sealant.
Old May 8, 2008 | 10:15 AM
blazinloud's Avatar
interesting
Old May 8, 2008 | 01:26 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
I have double lined in my truck but then again my sub weights like 100 pounds.
Old May 8, 2008 | 05:21 PM
blazinloud's Avatar
and i was sure you'd be the one to know that size dosent matter[8D]
Old May 22, 2008 | 12:27 PM
The A Team's Avatar
The A Team is an unknown quantity at this point
ORIGINAL: blazinloud
Mr. Loud where were you at the Sask SPL shows?
gmon3y15
Apr 2, 2014 12:18 AM
schnitzer00
Apr 12, 2007 07:53 PM
vdog
Jan 10, 2007 04:46 PM
jagblazer01
Oct 30, 2006 01:29 PM
XBlazer01
Oct 14, 2006 11:23 AM
