post pics of that system setup
im trying to get ideas for the system im making but i wanted to see what you guys have done with ur setups
i have 2 12'' Alpine type R subs with an 800w amp and 1.0 cap. attached everything to the box an ran my wires up both sides in the back panels, mine is only a 2 door though. have a JVC deck but it doesn't have sub control so i need to get a bass control for under my dash. this is the only pic i have sorry!
i just got done putting in some jl audio 10's and a 1000 watt crunch amp . ill post pics soon i still need to get a cap and figure out how to get the back glass to stop rattling
caps do more bad than they do good. Might as well wire up a couple double A's.
for the back glass get some weatherstripping for home windows and put a strip along the inside ridge of the glass, sometimes you need to double it up but it will prevent it from rattling/squeeking
pic of mine \/
pic of mine \/
polk SR series 10" with SSL 2000 watt mono (700 watt rms) also have a 1600 watt 4 channel soundstorm amp for the 4 6 1/2" polk dbs, 2 4x6 polk db's, and two 6x9 polk mm's
here is my 2 door system. i myself have the stupid spare tire in mine and refuse to take it out while it's my daily driver.
I haven't carpeted the box yet either. i'm still trying to decide on what material to use and if i like the ported box or not. it gets loud but i'm a crisp sealed box kind of guy. SPL is awesome and such but i like clear music
And to stop the annoying glass rattle. I went to Kmart and bout the weather stripping and traced it around the glass where it meets the truck. just do 3 sides and you're fine. If you try to do all four with it you'll have issues closing the glass. i have almost 0 glass rattles. i've tried the idea of taping the u bolt but it didn't help so...
i tired that and still no luck. mine doesn't really rattle anymore so i'm not too worried. Once in a while i'll get the chatter but with the 3 sides lined i'm set
i had different issues to deal with than most on here since i have 2 compressors and a 12 gallon air tank in the back also
