Question about stereo instalation
Hi guys!
I plan to upgrade my sound systeme and i have a few question for you My blazer is a 99 LT 4dr with 6.5" speaker in all 4 doors and 2 tweeter in the dashboard... Everything oem. Setup would be : (4) Door speaker 6 1/2 Alpine SPS-610 (2) Dash speaker 4x6 Alpine SPS-406 HeadUnit Alpine CDE-143BT Without amp and sub (planned for later) I'd use oem wiring, cut the wire right before oem speaker and use push-on connectors, my question is about the 2 dashboard 4x6 instead of the tweeters... Can i put these there without other wiring modification? Also i have a problem with my left rear door speaker, someday he is working someday he is not... I check wire at headunit harness and in the door evrything look fine Is it possible that the delco headunit cause that? Thanks for your help guys! |
Originally Posted by Alexys4530
(Post 627656)
Hi guys!
I'd use oem wiring, cut the wire right before oem speaker and use push-on connectors, my question is about the 2 dashboard 4x6 instead of the tweeters... Can i put these there without other wiring modification? Thanks for your help guys!
(Post 627656)
Hi guys!
Also i have a problem with my left rear door speaker, someday he is working someday he is not... I check wire at headunit harness and in the door evrything look fine Is it possible that the delco headunit cause that? Thanks for your help guys! I would switch it out and see how it goes. |
I believe in the dash you will have to remove the bass blocker that is wired in line with the tweeter.
(Post 627700)
http://i58.servimg.com/u/f58/16/04/12/87/image10.jpg Also what do you guys think of my speaker/headunit choice? And wich amp/sub should i use with those? I choosed these speaker cause i got the 2 4x6 for free so.. Thanks!! |
(Post 627700)
Sorry for wrong advice op Thanks for correcting me Rich Edit: alpine makes great stuff op, I'm sure you'll like it. |
