radio help!
Ok Ive got and 87. I just got the truck and it came with no radio. So i went out and got the wiring harness got it all wired up, hooked up the radio and the damn thing doesnt work. Went and took my radio out of my other car and hooked that one up, still nothing. Ok so any info on the wiring and how i go about trouble shooting this woulod be greatly appreciated
RE: radio help!
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4″ x 6″ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: 6″ x 9″ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue From a quick search on google |
RE: radio help!
nice post cr... i needed that a couple days ago... hahahha....first off check and make sure ur fuses arn't blown, then if u have a volt meter check ur constant power (yellow wire)and c if u have 12v, then ur acc (red wire)and c if u have 12v when the car is on... both of these us ur ground wire for ur ground or u can use ur key hole for the ground...
RE: radio help!
thanks yeah first thing i checked was the fuses but of course it wouldnt be that easy. im gonna go ahead and check on the volts tomorrow thanks
| All times are GMT -5. The time now is 04:23 AM. |
