removing oem keyless entry from 94 Blazer
anyone ever done this? i'm tring to remove the oem keyless entry fron one 94 s10 blazer and put it in another, thanks.
RE: removing oem keyless entry from 94 Blazer
well, if you are trying to put a new one in, do just that. you don't have to mess around with removing the old one.
I believe he is trying to take the RKE out of one vehicle and put it into another.
If both have the wiring, then you should just be able to swap out the RKE module. If someone else doesn't get back to you before I get home and get my references, I'll tell you where it is. |
yeah, if you could tell me where the RKE modual is, it would help me a lot, thanks!
