replacing door speaker in 99 anything speical about getting door panel off?
I am either going to replace or do PettyFog's trick to fix the driver's side front door speaker. Is there any trick to get the door panel off and back on or any advice for it's removal and re-installing?
Are there any screws that need to be removed or is it all of those little plastic fasteners? |
There is a screw under the door handle and one holding the plastic piece on the corner...other than that it should just be the plastic clips u just pop off
And be prepared to have some epoxy resin or an ABS glue just in case any of the clip holders are cracked or broken. I had that issue when I tried to carefully take one of my door panels off.
well I got the door panel off and got to the speaker, I think I fixed it we will see the cardboard around the outside was un-bonding so I glued it back up, 24 hours later no popping noise any more.
Awesome Bro.....
| All times are GMT -5. The time now is 02:40 PM. |
