running two switch wires
Ok right now I have the switch for the relay for my DRL disable/Quad Beam setup running in the fender and then in the opening for the door. I want to run this through the firewall somewhere I also plan on installing an air horn so I want a switch for that too near the driver somewhere. Is there a hole I can run these two rather small activator wires for relays through the firewall on the drivers side?
RE: running two switch wires
Anyone I know there is a hole for wires on the drivers side that has at least 100 running through it, but its way too tight to sneak two more in.
