speaker changes, NEED SOME HELP
I want to change the speakers in the front doors of my 2000 blazer. There is a lt. blue and dark blue wire attached to a clip and plugged into the factory speaker.
Can i cut those wires and hard wire them to the new speakers or do i need a special connector? |
RE: speaker changes, NEED SOME HELP
you can strip em and splice onto em.
Either or, you can cut them or splice them. You could even go to solder if you felt like taking the extra time, which in my eyes is worth it.
Thanks for the info. I am going to solder the wires because that is what i did for the back door speakers. What colors ar the positive and negative wires for the driver side and passenger side front doors?
What colors are the positive and negative for the front door speakers for both passenger and driver sides?
should be tan+/grey- drivers and lt. green+/dk. green- passenger...
| All times are GMT -5. The time now is 01:32 PM. |
