Speaker size...
can anyone tell me what the stock speaker sizes are for a 2001 blazer? i have a 2 door, i need the dash, door panel and rear speaker sizes as id like to replace them eventually. also how ho i get to the rear speakers?
RE: Speaker size...
dash: 4x6
front doors: 6.5 rear: 6x9 |
RE: Speaker size...
Thank you very much. any idea how to get to the rear speakers? does it involve removing the entire plastic peices?
RE: Speaker size...
I replaced mine a couple weeks ago. Ya, for the rear you got to take off that rear interior panel. Not so hard to do, you will need a torx bit for the seat belt bolt. I think the size was a T55. Good Luck.
RE: Speaker size...
there will be a small plastic cover reveling two screws in the rear door armrest/handle thingy then there is a trim piece along the window you take this one off and then if i remember correctly there is a screw behind the door handle you remove. once you have done all of this, you can use a panel tool (or if your cheap like me and use a small piece of wood as not to mar the paint.) and work your way around the the panel and the frame of the door. then you need to pop out the window switch from the back. there go! I can take pictures if you would like me to elaborate. just ask
RE: Speaker size...
(Its a 2dr Itown) Just be careful poppin the panel off.
RE: Speaker size...
sorry wrong pic above. Just flip up the cover and there you go.
[IMG]local://upfiles/8645/566B098F12CB40BD915DE31F1F46ADB5.jpg[/IMG] |
RE: Speaker size...
ok great, thanx so much. im gonna swap out all my stock speakers with sony xplods. had them in my old car and loved them.
RE: Speaker size...
Looks liek Jay is the only one that caught that it was a 2dr...Rear speakers are 5-1/4" not 6x9...And Honestly, I would rather have factory speakers than Sony Xplods...
RE: Speaker size...
I'm sure 5 1/4 speakers will fit but 6x9's are the way to go. I agree, Sony xplodes NOT the way to go, Pioneer, Kenwood, even those cheap Insignia's are a much better choice.
