-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Stereo install problems (https://blazerforum.com/forum/audio-video-electronics-8/stereo-install-problems-63946/)
Ckemp Oct 12, 2011 07:59 PM
I'm trying to install a cd player in a 1991 s-10 blazer, and have run into a problem. When I disconnect the black harness that has the constant 12v, ground, and illumination wires, from the stock radio, the dash lights go nuts.
The new cd player doesn't have a connection for the illumination/dimmer wire, so i would assume I need to leave it disconnected.
WTF, am I doing wrong?
ryguy013 Nov 20, 2011 10:19 PM
RE:
ok, whats the wiring color codes for the new deck's wiring harness (btw a deck is a stereo if you dont know) and are you using wire splices and crimps to connect it, or did you buy a wiring harness adaptor (i recommend them btw)
MTopper Nov 22, 2011 01:28 AM
what is the new radio? I would advise buying a wiring harness also just because it allows you to return to stock later on if you choose to, this is assuming you didn't buy one already.
Honestly, i have never seen a radio without an illumination wire off of it but, thats me. it could happen.
