Stereo Wiring and Install Parts
#131
The po cut the harness and theres a purple with white stripe, grey and green wire, what do these go to?
#132
So on the 1st gen s10 blazer you have 2 different parts listed for the wiring harness and the dash kit but you only need 1 of each correct? it is just which brand you want?
#133
so im installing front speakers....i pulled out my FRONT RIGHT door speaker, and the wires are lightblue and dark blue.
according to this diagram below, they should be Lgreen and Dgreen??...im so confused!
installed my deck properly but the speakers dont sound right... please help!
i have a 2003 blazer...the diagram also only lists front and rear speakers...what about the dash tweeters...
seems like my whole right side is backwards...so i switched the front and rear and tthings still didnt work...am i missing something?
For Blazers and S-10s (including Bravada, Sonoma, Jimmy, Full-Size) the actual stereo wiring is as follows Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
For 2002 up blazers the wiring is as follows:
Radio 12v orange+radio harness
Radio Ground black-radio harness
Radio Ignition dk. green+radio harness
Radio Illumination gray (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray+,- radio harness
RF Speaker +/- lt. green - dk. green+,- radio harness
LR Speaker +/- brown - yellow+,- radio harness
RR Speaker +/- dk. blue - lt. blue+,- radio harness
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Power Antenna N/A
#134
there are two harnesses on the factory deck. i am only using one. what will i lose? rap system? or just chime and radio on till door open?
#135
i was just gonna throw 2 cents in. if you decide to bypass your bose system just know that the bose speakers are 2 ohm and most cd players are only 4 ohm stable so there is a possibility that you could burn up a head unit. i would recommend replacing the bose speakers with 4 ohm or higher impendance speakers. You can either buy a plate for the doors (8 to 6 1/2 or whatever size your changing to) or you can do like i did and make your own out of 1/4 inch mdf. hope this helps and maybe save some head units
#136
#137
Bose systems use 8 ohm speakers. They are lower impedance than normal speakers, and thus are easy to blow up. That is the reason it is suggested to change out the speakers if you do the head unit. You will also have to redo all the wiring, as the Bose uses an amplifier somewhere in the system.
Do BOSE Car Stereo Speakers Differ From Ordinary Speakers? [Archive] - Straight Dope Message Board
Factory Bose speakers ohm rating... - 6speedonline.com Forums
2002 Blazer Xtreme/Bose System - General Audio - Cant find a category for your question? Ask here. - SMD Forum
idk if you are thinking of automotive bose but most of bose automotive applications are 2 ohm. Plus i just probed my factory bose system 8s that was in the door of my blazer just to make sure.
#138
#139
8 ohms is never normal. Otherwise, yeah, I was wrong.
#140
im trying to install a kendwood HU in my 01 blazer w/BOSE..there is only 1 small plug on the back of the stock deck, not 2 like the non bose systems.....are the wire colors the same as non bose systems? if i can use the factory bose amp to power the bose speakers that would be best, since i dont feel like frying my headunit because of the 2ohm speaker rating...what is the best way to wire up my kenwood? or is it possible to bypass the amp without causing damage to my reciever? ive been researching this forever it seems and keep getting conflicting information
