-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Stereo wiring problems (https://blazerforum.com/forum/audio-video-electronics-8/stereo-wiring-problems-7639/)
robar144 Dec 28, 2006 07:52 PM
97 Blazer - 100k and still runnin strong!!
Hi all, the only speaker that is working is the drivers door speaker. Sometimes the others will work after hitting a bump. Blazers love bumps!!! :O)
Question is ... do the speaker wires run strait to the speakers after the factory plug or are there other connections that I should check. I just installed a new stereo and I still have the same problem. :O(
Thanks
Robar
elementx440 Dec 28, 2006 11:31 PM
RE: Stereo wiring problems
After the wiring harness, they should run directly to the speakers. Start tearing your panels off and checking them. I get the 'ol soldering iron out and make a REAL connection! Come to think of it, one of my speakers ain't working either, one of the rears...
hillbillyinOhio Dec 29, 2006 12:16 AM
you prob have loose connection in one wire, make a dead short. Run all new wiring. Pretty easy to do. have done it three times in my 97. once with 16 ga, once with 14 and now have 10 all the way around
and BTW, I have 179000 on mine and still running strong.
robar144 Jan 1, 2007 11:28 PM
Thanks ... After trying to get at the oem harness I have decided that I'm gonna run new wires. Thanks for your comments.
wolv2401 Jan 2, 2007 11:55 PM
Honestly, I would try "popping" the speakers first. You can do this by taking a set of speaker wires and touching them to the ends of a 9V drill battery. Just put the positive speaker wire of one speaker on the positive end of the battery and the negative speaker wire onto the negative end of the battery. If you don't hear anything, there is a good chance that those speakers are blown. You should hear the speakers make a pop and the cone will move out while the wires are touching the battery. Do not use a battery greater than 12V, though. This is the method that is used first at the Best Buy I used to work at.
elementx440 Apr 11, 2007 01:02 AM
9-volts may damage the coil,
I've always used a AA battery or C battery, any little 1.5v cell works fine.
You need to flip the wires/battery polarity to get a littl e "pop" each time...
hillbillyinOhio Apr 11, 2007 01:11 AM
a 9 volt battery will not damage the speaker in any way.
