Community
Search
sub angles
Old 09-29-2008, 07:46 PM
NVANZEE's Avatar
Default RE: sub angles
so it doesnt matter if they are connected or not. correct?
  #32
Old 09-29-2008, 07:50 PM
kornkid683 is an unknown quantity at this point
i had 2 12 inch mtx jackhammers i bought for arouond 425 bucks at circut city and i got the jack hammer amp to. those right there plus my cheap door speakers were enough to shake some building in my town like the glass would shake. i would shake my car and my friends car right next to me.
  #33
Old 09-29-2008, 08:22 PM
Blazin_Jason's Avatar
ORIGINAL: kornkid683
  #34
Old 09-29-2008, 08:31 PM
NVANZEE's Avatar
ok if i were to get 2 of these http://www.woofersetc.com/index.cfm?...roduct_ID=2206 what amp should i get. since those are a little pricey i will probably go with these http://www.woofersetc.com/index.cfm?...roduct_ID=2200 or these http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_I D=6894. If you could recommend an amp for all 3 set ups it will probably give me my final decision. Also what is you opinion on the ones jason suggested compared to these
  #35
Old 09-29-2008, 08:36 PM
I wouldn't buy those. A) too much money B) It's MTX j/k :P
  #36
Old 09-29-2008, 09:23 PM
bobditts is an unknown quantity at this point
The 8500 series weigh 50lbs a piece. They need a MUCH larger enclosure than 1 cube. I know because I ran 2 of them in my sedan. I tried many different enclosures for them and they shined best in 1.75 cubes AFTER woofer displacement. Yoou really need to start looking at woofers that will work in your enclosure rather than finding a woofer and hoping it will fit. The MTX 5500 series is perfect for your situation if you want MTX. MTX makes very nice quality woofers.
  #37
Old 09-30-2008, 05:25 AM
NVANZEE's Avatar
ok thanks what amp would you recommend for those? any of the ones you listed earlier?
  #38
Old 09-30-2008, 06:40 AM
yep yep. All of the products I recommended earlier are quality products. Ive had experience with all of them. Very nice amps. Id lean more towards either of the alpines over the JL though.
  #39
Old 09-30-2008, 04:27 PM
NVANZEE's Avatar
ok, would this amp work? http://www.woofersetc.com/index.cfm?...roduct_ID=4738 I really like the looks of it
  #40
Old 09-30-2008, 05:26 PM
That is a great amp. Im running a pair of the PDX amps in my sedan. Way out of your budget though unless you bumped it up to $1000. I would definitely recommend it for both its size and efficiency.
Quick Reply: sub angles
